Roof Insulation for Shipping Container Dwelling
Hey guys, I’m sure I am making this more complicated than it needs to be…
Building a small shipping container cabin (I know, I know). We are outsulating with eps and polyiso on the walls, about r15 or thereabouts. On the roof I want to do 4″ of polyiso for r20+, but we get snow so I want to pitch the roof a little (shed roof, no eaves). So with that in mind I cant figure out if I should keep the 4″ foam as close to the container roof as possible and build a vented or unvented roof above that (venting seems tricky without eaves or ridge and using corrugated roofing), or do I put the foam as close to roofing as possible and have an unvented sealed air space between the container roof and “new” roof?
Thanks much!
Keep the foam tight to the container. Given the air and vapor tightness of a steel container, I wouldn't worry about venting space above it. Unless you are concerned about ice dams.
Thanks for the reply! This was my thinking too, my only concern was creating a superheated unvented space above the insulation (hot dry climate zone 3) in the summer and losing efficiency having that trapped air against the insulation?
