Vented attic insulation detail
![](https://secure.gravatar.com/avatar/e2ebe9acf2a65c9698dcb085588a3a57?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
I asked about a 2 component attic insulation package with storage space in between a few weeks ago and was thoroughly dissuaded from pursuing that design. We are doing a remodel on an 1879 victorian in zone 5, the roof and exterior vinyl siding were done about 9 years ago so an exterior wrap is not in the cards, unfortunately.
I am wondering what you all think of the attached design detail. I have access to the 4×8 foil faced polyiso as seconds, usually with an uneven edge or damage to the foil, at about 1/2 price. There is a lumberyard near here that stocks this material and I have used it in several large projects with good luck.
At the juncture between stud bay and ceiling I would intend to have the SPF contractor seal the foam board into the wall spf to create a near continuous envelope all the way around the house (except for the rims joists)
My rough math puts this at about an R21+R22.4+R16.8 so a total of R60.2 which would have me well over our local new build requirement of R49.
