Vent to nowhere
![](https://secure.gravatar.com/avatar/97f4b970af1a3650954e8600f7e2bc3f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I’M VERY EXCITED TO FIND THIS SITE!
We recently moved into an older condo building. I removed the cover on one of our bathroom fans to find it is vented to nowhere. Theres nowhere to go with it the floors and ceilings are concrete. The exterior walls are not an option. I’d love a solution. Being in FL moisture is always present.
Thanks Everyone!!!
Hi Condo_Nic_FL
Did you actually remove the fan so that you were able to see that there was no ducting, that there isn't a chase framed below the concrete floor above?
If there really is no where to duct the fan above, you could install a wall mounted bath fan. I can't give any product recommendation because I have not installed them, but most fan manufacturers offer them.
I agree with Brian. Verify there is no path to the outside. You may need to borrow (or buy a cheap one from HF) a fiber-optic scope to check if space is tight. If you are on an exterior wall you could go sidewall ventilation, IF the condo association will allow that.
Is there an operable window in the room?
How old is the condo?
There is almost always somewhere to send duct work, it just takes more work sometimes.
I bet this is connected to something though...
Have you talked to your condo association? This may be a common issue.
Condo,
As Steve said, any work beyond the surface of your unit is the responsibility of the condo association. It is a defect that they need to fix. Owners making modifications to common walls or floors shared by other units is not a good idea.
Thanks s Everyone for your experience! I'm going to do more investigating.
