Vapour Barrier in Humid Climate for CLT
![](https://secure.gravatar.com/avatar/d72903370172dafb13b95ac75fb4130a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
We’re building a CLT home in Australia in a zone 2 climate.
I’ve seen a number of different configurations for the placement of a vapour barrier in CLT construction, but mostly for cooler climates.
In humid climates, WUFI analysis has suggested placing the insulation to the inside and having a vapour barrier on the outside of the CLT, which seems to defeat the purpose of CLT to an extent.
https://www.diva-portal.org/smash/get/diva2:1222631/FULLTEXT01.pdf
My initial thought is to protect the CLT during construction with a house wrap, insulate externally, and wrap a vapour barrier outside the vapour open exterior insulation. Or is that overkill?
