Vapour barrier for odd insulation order
![](https://secure.gravatar.com/avatar/2d13630e1401a145c757278fbf3bd624?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Hello, first time poster.
I insulated my 16×24 workshop with recycled 4″ XPS(r20 theoretically) in the 3.5″ stud bays + left over foam from a 2 part kit for the gaps/stud faces. This has been fine, but I want to actually finish the interior wall as it’s just the exposed XPS at the moment. My messy spraying would make it difficult to finish so I was going to add an interior stud wall and some extra Fiberglass insulation I had lying around (r14).
Would a vapour barrier/retarder in the form of 6mm poly be needed? I’m going to finish with t&g 5/8th plywood.
Also, I stood the 4″XPS off the exterior siding(no sheathing, just the wood siding) with some 3/4″ strips of wood, but there’s no specific air flow in that cavity.
Also, live near Ottawa. Zone 5 I believe.
Thanks,
From a building science point of view, it's not needed, unless this is a workshop for something that involves boiling cauldrons of herbs or some other unusually intense source of moisture.
From a code point of view, it might depend on your local inspector but you can probably argue that the XPS is your vapor barrier.
If I try and keep the hammer away from my thumbs it should keep the tears from condensing on the back of the XPS.
So just so I understand properly, the interior 'warm' surface of the XPS will be warm enough to not become a condensing surface even though it's going to be somewhat insulated from the hear source by the new Fiberglass batts? And the RH is probably fairly low because it's a workshop?
Thank you,
Yes, you understood correctly regarding why the XPS won't be a condensing surface and also understood correctly about keeping your thumbs safe.
