Vapor Permeable Exterior Insulation
![](https://secure.gravatar.com/avatar/c630ccf24b8f8de3704be81ab9b05277?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I can’t seem to find any Rockwool or Gutex products for my exterior insulation. We already have a vapor barrier on the interior side of the wall, so, I’ll need a permeable option on the outside…at least I assume I do. Any ideas? It’ll be corrugated metal siding. Could I compress 2×4 Rockwool batt? I could skip the exterior insulation, but I’d rather not.
It’s been a while since I’ve paid attention to what the current practices are.
Thanks!
Matt
The right thickness of unfaced EPS will work well.
Use the upper right search button for more info.
Matt,
Make sure to vent the bottom of your corrugated metal cladding.
My go to budget permeable foam is fiber faced roofing polyiso. This comes with a fiberglass facer, depending on the manufacturer and thickness, it tends to be above 1 Perm.
The facer on this foam absorbs water, so your WRB needs to go over the foam. If this is not a type of install your contractor is comfortable with, go for unfaced EPS/GPS or low GWP XPS foam as Jon R suggests.
