Vapor Control for Continuous Insulation – Zone 6
![](https://secure.gravatar.com/avatar/be182cc13bc692a2f4a73aa906a221f6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hi all,
Looking to install continuous insulation with no cavity insulation on a tiny residential home in Zone 6. My question is, do I need a vapor barrier between the insulation and sheathing, or am I good with just taping and sealing the joints in the polyiso?
thanks!
jb
jb,
You are fine with what you have.
Taping the joints will be part of your air-sealing strategy. The layers of foam and plywood will act as vapour-retarders, and vapour retarders/barriers don't need to be sealed.
