Vapor barrier tiny house on wheels
![](https://secure.gravatar.com/avatar/98d2428a754ac09125001c49878c97cb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I have a tiny house on wheels I’ve started. I used a poly plastic as the vapor barrier on the subfloor. Now that the frame has been built, I’m worried about moisture, that I can see in one corner. It’s not much but I can imagine there’s more where I cant see. What should I do since I already have the frame? Is there a way to let it breathe? Or to protect against mold? Should I seal the edges with caulk?
Thank you so much for any help!
SarahL.
