Vapor Barrier Termination for Monolithic Slab On Grade
![](https://secure.gravatar.com/avatar/89fba2c2e72c5068552781e54ae5b5de?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
For a monolithic slab-on-grade, if I run the vapor barrier (Stego Pango) below the slab then down, under, and back up the outside vertical face of the turned-down footing, how/where do I terminate it? Should I bring it all the way up to the bottom of the Zip sheathing and then use Prosoco Seam and Joint Filler to bridge that sill connection? Would the damp-proofing treatment then go outside of the vapor barrier and the slab edge rigid insulation would go outbound of the damp-proofing? What product do folks here like for damp-proofing the outside face of a monolithic slab on grade?
