Vapor barrier in showers with exterior foam
![](https://secure.gravatar.com/avatar/bd887af68f9c958b59e6dbafe7d9931d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
IF anybody has any advice on what to do with a vapor barrier behind hardi backer for shower tile walls that would be helpful. I’ve got a few inches of exterior ISO and don’t want to sandwich the walls with vapor barriers. Thanks
Stan,
The area behind a shower is small. As long as the wall assembly is dry on the day that you install the interior vapor barrier, go ahead with the job and don't worry. The two vapor barriers aren't going to be a problem in this situation.
Ok thanks Martin. I guess it brought a little extra worry just because all of the humidity from steam and what not.
Stan,
What are you doing elsewhere in the house?
No vapor barrier elsewhere, just unfaced batts
