Vapor barrier between layers of gypsum board on a ceiling
mhntr | Posted in General Questions on
I have a home built in 1973 in climate zone 6.  I am going to be adding a layer of 1/2″ gypsum board to the ceiling to cover the existing popcorn ceilings which may contain asbestos.  The house currently has only some paper above the existing ceilings to act as a vapor barrier and I have been advised by contractor friends to add 6mm plastic between the layers of gypsum board.  I would be fine with putting the plastic between the gypsum board and the joists if I could do that, but putting it between the layers of gypsum board makes me nervous about moisture damage to the original ceiling during the summer months.  Is putting a vapor barrier between the two layers of the gypsum board ceiling a good idea or should I not worry about adding a barrier?  Thank you.
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:”Table Normal”;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:””;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:”Calibri”,”sans-serif”;
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:”Times New Roman”;
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:”Times New Roman”;
mso-bidi-theme-font:minor-bidi;}
    BILL WICHERS | | #1
    I don’t see any need for the poly unless you’re in an area where that’s a code requirement. The drywall alone is a good air barrier, and the drywall is also a good barrier to encapsulate asbestos since the asbestos fibers won’t penetrate the drywall.
