Vanee advanced controller for ERV features
I’m getting an ERV, I’m looking for one that allows me to make incremental adjustments to the cfm output. Someone came in and pitched me a Vanee AI series V150E75NT with an “advanced touchscreen controller” and told me that it would be possible to make small adjustments to the CFM.
But I couldn’t find exactly what I was looking for in the controller manual documentation. Linked here.
https://manuals.plus/m/b56bde8402f29202de68f7611af63dcca38bbff17f4104faaf438890ef044491_optim.pdf
I don’t see anywhere where you can adjust the CFM in increments in the documentation. But I do see a “settings” icon next to “modes” on page of the manual PDF.
Does anyone who has experience with this controller know if there are those CFM adjustment settings in that part of the controller? Or elsewhere on the controller?
On the unit itself I do see where you can adjust the CFM, maybe that was what my HVAC guy was referring to? Isn’t that like for setting it up or calibrating it?
I’m not sure if that is as convenient as having it on the control panel.
UNIT LINK
https://broan-nutone.com/en-ca/product/freshairsystems/v150e75nt
I recently installed this controller and it’s pretty disappointing. You cannot specify cfm, there is simply low med high. Set of min max is on machine itself. My biggest complaint is the screen cannot turn off. Who makes a wall controller with a light up screen that can never sleep?! Just be careful where you place it. Attached are a couple of images.
