Using Fiberglass Rebar
![](https://secure.gravatar.com/avatar/c563c5239519a23a8df763d65db3f151?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
HI, I was wondering if anyone has knowledge on using fiberglass rebar in the walls of an ICF house? I am interested in this as it would lower the electrical and magnetic conductivity. I am sensitive to EMF’s . Here is one such product. http://www.fiberglassrebar.com/why_composites.htm
I can't speak to the fiberglass rebar product, but I wanted to point out that if your goal is to minimize EMF in your home, then having metal in the walls is a GOOD thing. The EMF will tend follow the conductor, rather than passing through the interior space of the house - this is the principle behind a Faraday cage.
Consider using steel rebar, and a metal roof!
That is very interesting. I will have to research Faraday cage. Do you have any recommendations on metal roofs? Thank you.
Don't worry, your days are very numbered. Less than a week to go.
AJ -- You made me chuckle!
Very funny, I am more concerned about EMF's I think I will start a new post that asks that question. Thank you
