Unvented Rafter Bays over Unconditioned Space
![](https://secure.gravatar.com/avatar/07ad9818878408a8fa2f3e6540dccb90?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
I have a question regarding an unvented rafter bay for a roof the is over an exterior deck, not conditioned space. Do I need to apply IRC R806.5 or is that just for roofs over conditioned space? I don’t want to create any condensation issues as the project is in the hills above Reno. Hot in the summer cold and snow in the winter.
Thanks,
Ken
I’m giving your question a bump. While you wait for experts to weigh in, consider these words: “Unvented roofs in the snow belt may still need some type of venting to keep the roof cold and prevent ice dams.”
Thanks Kiley. I appreciate it.
Are the rafter bays enclosed? (Ie, do you have a ceiling over the deck, or exposed rafters). If exposed, I’d say certainly not. If enclosed I’d also likely say you don’t need it, but it gets a bit more iffy. You want to keep the whole assembly the same temperature. Exposed bays makes this easy. An enclosed bay has the potential to have a temperature gradient that would cause condensation. Honestly though this seems a bit theoretical. I do not believe IRC requires it.
Thanks for the response. Yes the rafters do have a ceiling so the bays are enclosed.
Ken
IRC R806.5 should be for "above conditioned space". But I don't see where it says that. It gets even trickier if the space is occasionally conditioned.
I've seen some moisture problems in/above unconditioned spaces, but never in a dry place like Reno.
