Unavoidable stack and minisplit conundrum
![](https://secure.gravatar.com/avatar/e393923b14fafccc98f84135b7dbce28?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Good morning! My recent money pit acquisition has a very serious stack problem. It has been 90 degrees on the second floor and probably 65 on the ground floor. I am going to do my best to try to ‘plug leaks’ however I expect that it’s going to be futile.
Is there a way to ‘move’ the air around the house to put some of this stack effect to use?
Also, basement floor radiant heat instead of putting a minisplit down there- would that be worth it? It’s never hot down there but I expect that once I pull up that super cushy carpet and leave it concrete it’s going to be frigid.
Radiant heat on basement minisplits first and second?
Thanks!
