Trying to understand Code required insulation for condensation control
![](https://secure.gravatar.com/avatar/f2b7adba225fa7cdc3c8d3f0c721f906?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
When 2021 IRC raised insulation levels it did not make a corresponding increase to the condensation control insulation levels. Consequently 2021 has lower ratios compared to 2018.
Does that mean these lower ratios are actually fine from a condensation control perspective? If so, then shouldn’t they work equally well for 2018 insulation levels?
Ex. Zone 7
2018 | Total R 49 | Condensation Control R30
Ratio 30/49 = 61%
2021 | Total R 60 | Condensation Control R30
Ratio 30/60 = 50%
The original numbers were based on Building Science Corp research and estimates. They wanted to use ratios, not hard numbers, but the code council thought that would be too complicated.
I agree that the numbers should have changed with the overall R-value update, and I use the original ratios. The way the code change process works, someone needs to propose and defend an amendment.
