Todol Purstick for adhering subfloor?
ken_o | Posted in General Questions on
Does anyone have any experience using Todol’s Purstick foaming adhesive as an alternative to conventional caulking-gun construction adhesive to adhere the subfloor to the joists? I will be using 3/4″ OSB T&G subfloor and TJI 210 (2 1/16″ wide) joists. This will be nailed together also.
Pur Stick
This is sounding like a good product, with overall cost lower than the tube adhesive. I’m wondering if it is too good to be true…
Thanks.
    MALCOLM TAYLOR | | #1
    Ken,
    I've seen the ads for a couple of years now, but never seen the product on a site. That may mean nothing more than builders are conservative and slow to adopt new products, but it sure hasn't caught 0n around here anyway.
  2. Patrick_OSullivan | | #2
    Can't vouch for that product in particular, but Advantech Subfloor Adhesive (https://www.huberwood.com/advantech/subfloor-adhesive) is excellent and widely available. I wouldn't hesitate to use it again.
    1. ken_o | | #3
      Patrick--This sounds encouraging. I'm not planning to use the Advantech subfloor system. Does this stuff work with regular T&G OSB, and does it work with any (such as Pageris) gun or do I need to use their gun? Thanks for the info.
      1. Patrick_OSullivan | | #4
        Should work with any normal sheathing and joist combination. You just won’t get their squeak free guarantee that they advertise.
        It works with standard foam guns. I recommend one with a longer nozzle so you’re not bending over the whole time.
    Michael Maines | | #5
    Ken, I have used cases of Todol Pur Stick but not for subfloors. I think it would work fine for that, though, and they list subfloors as a suitable use on their website. With no solvents or VOCs it's nicer to work around than most adhesives.
