To wrap or not to wrap (pipe)?
![](https://secure.gravatar.com/avatar/be424e72803f15043833b4f1544cf8a3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Currently, in the process of insulating a 4 foot basement poured concrete foundation wall. Photo below. I am putting rigid foam and then drywall. A few feet down the wall some horizontal pipes run across the concrete wall, practically touching the foundation. They have foam wrapping around them to prevent condensation and I will spray foam behind them.
Because I will be drywalling in front of them, I removed some of the insulation on the side of the pipes that is facing the interior, to ensure that warm from the inside can still continue to reach it, since I think the foundation will get colder once I put the foam board up, and I worry about the pipes freezing, since they are not very far below grade.
Since drywall will be covering the pipes, do I still have to worry about moisture from the interior reaching the pipes and condensation forming on the uninsulated part of the pipe inside of the wall?
There is probably low risk of freezing or condensation so I think either approach could work. Only cold water pipes will cause condensation.
Thanks for the feedback! I forgot to mention, climate zone 6a, basement usually kept at 50 degrees with about 55-60% relative humidity. The pipes are cold water pipes. Not sure if all that makes a difference.
