To Daikin DZK or not
![](https://secure.gravatar.com/avatar/d7b59cdd3f6dfe80abe0253c59dd64d2?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
It would be nice to have zones using a single indoor air handler. But my gut tells me that this DZK thing would cause way more friction loss and in the end would be less energy efficient.
Thoughts?
Do a good job of duct design and efficiency impact will be low. But only you can put a value on increased comfort.
Theses systems can certainly be made to work and can be reasonably efficient. It likely won't be as efficient as a couple 1:1 systems. The lower the load of a home, the less zoning is an issue generally. Good modulation also takes care of a lot of comfort issues.
One of the bigger problems will be that I think the smallest unit is 3 tons. Daikin equipment is also expensive.
See here for more discussion: https://www.greenbuildingadvisor.com/question/difficulty-finding-a-modulating-multi-zone-air-source-heat-pump
I am designing a fujitsu slim duct system and considering implementing a VAV of some sort to drop the temp of my little used conditioned attic space. It will be a slave with no ability to call for heat. This should work reasonably well as the space has a notably lower heat loss to volume ratio than the 2nd floor space served by the system. The biggest reason for doing this to stretch the cold weather capacity a bit further for short periods. It may yield some energy use benefits, but I will only push that so far due to moisture concerns. I still have some numbers to crunch to see if it will work and make sense. It will be a bit of a science experiment.
