Thermometer Setting
![](https://secure.gravatar.com/avatar/c2b18d807aeb9cd123d7ba47a7e41003?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I have a Fijitsu wall mounted thermostat I can’t get the temperature to set below 74 degrees fahrenheit in AC mode it is a Hylacon heat pump with two ducted blower assemblies independent of each other and in separate zones with separate thermostats.
