Thermofoil – any info?
![](https://images.greenbuildingadvisor.com/app/uploads/2024/02/28125812/9562-avatar-1709143092-100x100.png)
I keep running across Thermofoil cabinets that are touted as “green” because of their durability yet it’s made of vinyl and glued onto (not necessarily NAUF nor FSC certified) MDF. Do you have any info/opinions?
Thanks!
Bettina
Bettina,
The Thermofoil layer is just plastic. There is nothing green about it.
I've installed many white thermofoil cabinets. After 10 years, they look surprisingly crappy.
The white tends to yellow a lot. The screws strip out of the MDF.
Solid wood with a clear varnish is best in the long run. Any damage can be repaired with sanding and recoating, not possible with thermofoil.
