ThermalBuck and Window Rough Opening
![](https://www.greenbuildingadvisor.com/app/uploads/assets/avatars/19783-avatar-1610119178-100x100.png)
If you use ThermalBuck, do you need to make the window rough opening size an ADDITIONAL 1/2″ bigger on every side (in addition to the normal 3/8″ or 1/2″ allowance on every side for shimming and squaring). Or does ThermalBuck assume you’re going to have a fairly tight fit to the foam when you stick the window into it?
Add 1/2" on all sides: https://thermalbuck.com/sealants-frequently-asked-questions-faqs/
Is there a good way to insulate a sky light similar to Thermalbuck?
