Thank you helping me build this pantry
Thanks for everyone’s help, answering all my questions I was able to build this closet. Not perfect but good for my first time. I put my shims in to level door and now have a small gap. The whole frame is so narrow don’t want to add too much more to cover gap. Is there some kind of filler I can use, or some thin piece of molding that would look good here, picture attached
Building stuff gets easier as you gain experience. Everyone on here had t I start somewhere :-)
You might try some of the D profile weatherstripping between those doors. The “right” fix would be to shim out the frame a bit on the bottom until the doors are aligned, but that can be tricky.
