Tescon Vana Tape for Sealing Around Window Flanges
![](https://secure.gravatar.com/avatar/573f796f0c9f87363b2a38aec17430e6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
I’ve got some weird window bucks that I’ve flashed with FastFlash. The cost of materials and application is getting a bit higher than I’d estimated, and now my contractor is hoping to use tape for the final flashing piece — which, for us, is sealing around the window nailing flanges and connecting our Tyvek Commercial Wrap “D” (drain wrap /sheet WRB) to the window flange and/or fast flash.
Is it a bad idea to use Vana to “seal” the Tyvek and/or the window flange seams? It seems to be sticking fairly nicely and I have a roll on hand (vs. Contiga, which may take too much time to arrive).
I think it would work fine but I'd check with the supplier (foursevenfive.com) to be sure.
