Detailing an Overhanging Floor
![](https://secure.gravatar.com/avatar/9f0e1d7a4daefe8fcedcd01b2e374050?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
This may be an easy one. Half of the second story of the house I am designing and building will be overhanging the first floor and will be posted down to bedrock. This is zone 6. I have a very tight and well insulated (R-40 walls/r-60 roof) design in mind and am considering air barriers, moisture barriers, insulation and enclosure of the part of the floor that overhangs.
I will deck with advantec, so I imagine that is my moisture barrier. I don’t plan on using rigid foam or spray foam. The rest of the house will be dense pack cellulose, so I would like to use this in the floor if I can. I would also consider rock wool. If the floor framing is 2×10, I will have 9 inches of insulation. I would then add a thermal break in the form of rockwool comfort board, for example. I hope to leave it unskirted. My questions are…
1. Is R-40 enough in this situation?
2. Should I then add another air or moisture barrier (tyvek?) on the outside of the comfort board?
3. Would strapping it out and applying metal roofing be an advisable enclosure
Thanks!
Have you taken a look at GBA articles like this one?
https://www.greenbuildingadvisor.com/article/insulating-a-wood-framed-floor-assembly
stephenr,
1. R-40, with the rockwool as a thermal break should be fine. The comfort will depend a lot on how conductive the finished floor you choose is.
2. I don't see much benefit to having a WRB on the underside.
3. Metal roofing would work well. Some concealed faster types (like snap-lock) may sag a bit and need intermediate screws.
