Superstor indirect-fired water heater leak from aquastat
![](https://secure.gravatar.com/avatar/0d1771c55807046c71fb380feaa7ce4e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
I am seeking help with diagnosing what the potential problem could be. About two days ago I noticed water dripping from what I believe is the aquastat connected to the hot water heater on the outside. I am attaching photos for reference. We live in southwestern Colorado (climate zone 7b, elevation 7700′) and getting proper professional advice can take a few days to a few weeks. I just want to see what I should do in the interim to prevent more costly damage from occurring. Any help would be greatly appreciated.
I should also include that it is gas. It is set to 120 degrees and the leak is coming from underneath the bottom metal plating.
Thanks!
Could you include a couple pictures showing more of the ( all ) piping and where it is going ? Curious about the zone valve I see and other piping also
Take a look at these. Let me know if it helps. I appreciate the response. Also, the system seems to be heating the water fine so far.
