Subfloor Over Insulated and Vapor Barriered Concrete Slab – Do I Need It?
![](https://secure.gravatar.com/avatar/6648b85455a098d8cee001ad313d471b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Sub floor Necessary?
New Construction, Climate Zone 6
Walkout (or daylight) basement has crushed stone, 2 inch foam boards, and vapor barrier sheet under the slab. Below grade wall of basement has sprayed black waterproof stuff and perimeter drains
If I want to use LVT vinyl tile or other floating floor, do I have to install a sub floor using any number of material — Delta FL, Dricore, OSB, Plywood, dimple mat, or other? Way over budget already, and LVT manufacturer Flooret indicates no need for any material underneath their tiles. I know the ‘feel’ would be softer with a sub floor.
Thanks
stuartd,
No. I can't think of any vinyl tile or common floating floor system that isn't allowed to be installed over slabs.
If you want increased comfort, I would buy a flooring that has integral cushioning.
Dimple mats, etc. are remedial solutions to moisture problems for slabs that have not been properly constructed. You should be fine without them.
