Strategy for attaching rigid foam on exterior of brick facade
![](https://secure.gravatar.com/avatar/0e5ebbf52235eb31f4eb7dcc10360714?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I am looking for the best way to attach either rigid foam or Roxul Comfortboard to the exterior of a brick facade as part of a deep energy retrofit. The first level has brick facade and second level, vinyl siding. Anyone have experience with this?
Joel,
EIFS contractors use adhesive, as far as I know. You might want to contact an EIFS contractor.
For Roxul mineral wool, I think you would need to use masonry fasteners (either Tapcons or Hilti IDP fasteners). These fasteners require you to drill holes in the mortar or the bricks, so you'll need a masonry bit and a hammer drill.
