Strapping material for rainscreen…plywood fir or spruce?
unclejemima | Posted in General Questions on
I’m ready to put the strapping on-top of my WRB, only I’m not sure what the best choice is.
I want a 3/8″ gap, so cutting plywood strips is my only option (there is NO composite furring strips available in town…I called everywhere!)
I’ve got the option of 3/8 spruce with exterior glue, or 3/8 fur with exterior glue.
Does either have a lower tannin content that may deteriorate the WRB? Do I even have to worry about that? Should I back prime the strapping to avoid this?
I’m going to put cement board over the strapping then stone.
Thanks!
  1. brp_nh | | #1
    Cor-A-Vent Sturdi-Strips (3/8" deep) are available from ABC Supply Co. if you can't buy from a local supplier. Their website doesn't look good, but they are legit:
    https://abccatalog.com/view_product.asp?idproduct=2147801112
    We used these with the SV-3 product for a vented rain screen on our house.
    MALCOLM TAYLOR | | #2
    Mark, As far as I know Tyvek was the only WRB which had problems with deterioration due to cedar tannins, and they have since reformulated their product to address this.
  3. GBA Editor
    Martin Holladay | | #3
    Mark,
    Either spruce or fir will work fine. But I wouldn't use the fur if I were you.
  4. mtr7982 | | #4
    Martin,
    The Native Americans, the original fur rainscreen , I believe they turned the fur in which would've prevented thermal bridging to the tee pee support poles. Hmmm you have my wheels turning.
  5. unclejemima | | #5
    Thanks guys :-)
    Brian, thanks for the link. I'm in Canada so the weak CAD, shipping and Duties would kill me :-(
    Malcom. Good to know. I won't worry then.
    Martin, I'll use the fir. Its difficult to find exterior glue rated 3/8" plywood, but I did find the exterior rated glue and fir for a reasonable price. 99% are interior glue and usually spruce.
    Mr Miller...interesting reply :-)
    Thanks all!
  6. GBA Editor
    Andy Engel | | #6
    I used mason's lath. I suspect it was poplar, but it's cheap and 3/8 in. thick.
