StoGuard WRB
![](https://secure.gravatar.com/avatar/5730210db14ba879cf3601ecc4361563?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
Can one apply a product like StoGuard with EmeraldCoat WRB on OSB roof sheathing and then at a short time later apply a peel & stick membrane over it?
Will the peel & stick adhere to OSB covered with StoGuard WRB?
Peter,
I don't know. But since peel-and-stick membranes are waterproof, vapor-impermeable air barriers, I don't know why you think you would need StoGuard with Emerald Coat.
I agree with Martin, when applied correctly, peel and stick functions great in a roof application.
I am very interested in Liquid WRBs and the Air infiltration benefits they provide.
I am a bit confused (and always have been) as to how a roof (abutting fully conditioned space) can be very airtight given the gap necessary between the sheathing. I have started to lean more towards under roofs and over roofs as a configuration, with light colored exteriors to reduce the massive solar heating that dark shingled roofs transmit to the sheathing.
I know the answer put forth is always "spray insulation", but what happens when you need to replace sheathing in the future? I like the idea of building a 100 year wall but flipped over to be the roof, and using exterior (taped) foam over a liquid applied WSB and with butted sheathing.
