Steico Universal Dry versus Rockwool Comfortboard
![](https://secure.gravatar.com/avatar/6d42cec8e37223eb1d75def812977077?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
Can people weigh in on 2″ Steico Universal Dry (R6.15) versus 2″ Rockwool Comfortboard (R 8) for exterior insulation? There is a good source for the Steico close by and it is less expensive. We are building in Virginia so our winters are not as tough as up north so losing 2 R is doable. The Rockwool has better fire performance but the installation of the Steico is appealing with a simple tongue in groove board system that can stack up quickly. I am leaning toward the Rockwool because of our humidity and critters but I am trying to stay open to a wood fiber product. If anyone has taken a drive in West Virginia you will see signs objecting to the environmental damage of rockwool.
Lisa
Slightly better performance with Rockwool, and it's fireproof. Much lower embodied carbon in the Steico--depending on some variables, it may be even be carbon negative. It's also significantly easier to work with than Comfortboard. Unless you're in a high fire danger area, I would go with the Steico.
