Steel or wood studs for spray foam basement
![](https://secure.gravatar.com/avatar/545d33c2b9ef3483319472784cdc3bb1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
My client wants 4″ of closed cell spray foam installed in stud cavities in his basement. Location – Toronto, Canada.
What studs should be used to frame foundation walls with – steel or wood?
The debate is that 2×4 is taking 1.1/2″ of space that could have been filled with foam if steel studs were used instead since they are only about 1/16″ thick.
Your input will much appreciated.
According to an ORNL report, wood studs might degrade a wall's thermal performance by 10%, while steel studs can degrade it by 55%.
There is no more effective thermal bridge than steel framing.
Wow! 55% ??? I guess this dilema is solved.
Thank you very much for your response.
