Spruce versus pine species for exterior siding
Myrtleboone | Posted in Green Products and Materials on
Hi. I was originally planning on using horizontally placed pine boards for my house siding. Due to the time of year, there is a shortage of local pine and will not be accessible in the time frame I need. My local wood mill can provide spruce. He’s used it on his house and it has held up nicely. My plan is to back prime and use a solid stain on the exterior regardless of species (and use 3/4″ strapping behind it. Any experience with using spruce, its qualities and characteristics and is it good for this type of application? Thanks.
    Dana Dorsett | | #1
    Spruce is second only to cedar as a premium wood for clapboards & shingles. It tends to have less resin to bleed though the paints/stains than most species of pine, and in some climates can be left to weather naturally sans-finish like cedar. Like any timber product it's available in several quality grades, but if you get the good stuff it makes excellent siding- more rugged than cedar to dents & dings, but similar weathering qualities.
  2. Myrtleboone | | #2
    I was told that I didn't need strapping behind, as will have an airspace behind each board. Although, with it being clapboard, the top edge will be making contact with the house wrap.. Should I have one regardless?
  3. GBA Editor
    Martin Holladay | | #3
    Matthew,
    It's your choice. Your paint job will probably last longer if you include a rainscreen gap. For more information, see All About Rainscreens.
  4. wjrobinson | | #4
    Where I am all pine claps are spruce pine never eastern white or southern yellow or old growth red...
    Back priming is worth doing. Pre-coat for new construction. Rain screen is good but is another cost we add optionally. Customer preference.
