Spray foam wall and 2×6 framing: How to seal stud-to-stud cracks?
![](https://secure.gravatar.com/avatar/03dec816121a95b0a8bd231f385ee3dc?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I spray foamed my entire house. Roof trusses, wall cavity and even the floor.
We’re just getting ready to do electrical and mechanical rough in and the spray foam guys are going to come back and scrape any exposed foam off the face of the studs, and also seal the windows and stud-to-stud area.
What they are planning on doing is using acousti seal where 2 studs sit side-by-side and then put tuck tape over the acousti seal.
Is this a good practice or is there a better way to seal these joints? I’ve got a double top plate and double bottom plate. Should I do the top and bottom plates, as well as the wall stud joints with the acousti seal?
Any advice would be appreciated.
The caulked & taped approach as described is sound. It's just as important to treat doubled-up top plates in the same manner as the doubled-up studs, as well as a bead of caulk at the transition of the bottom plate of the framing to the sub-floor.
Is there any other options that might be better? If not, then that's easy as pie :-)
