Spray Foam Sealing Failures?
![](https://secure.gravatar.com/avatar/cff1a45ea4cb375f7c4275488c81f815?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Has anyone had direct experience or knowledge of spray applied closed cell foam insulation installed in newly framed stud walls having air sealing failures or gaps as a result of the wood studs shrinking after installation? Does the applied foam have enough bond and elastic properties to move with the framing lumber?
Thank you.
John,
You may be interested in reading a long thread at the JLC Web forum on the topic of spray foam shrinkage:
http://forums.jlconline.com/forums/showthread.php?t=29295
Martin, Thank you.
Just go with Nu-Wool certified contractor and you will be happy.
