Spray foam my ridge vents and soffits closed?
![](https://secure.gravatar.com/avatar/1b6d52bd32759265e042de3afe9784e5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Okay so I am investigating spray foam insulation for my garage. The most recent company I spoke with gave me a quote but also asked if I had a ridge vent. I said yes. They said they would also spray the vent closed because spray foam creates another atmosphere and we would not need it. Another atmosphere??
I don’t understand why you would want to get rid of the ridge vent. Can someone shed some light on this topic, I am in the dark.
Joe,
You didn't tell us where you plan to install the spray foam insulation.
If you plan to install the spray foam insulation on the underside of the roof sheathing of an existing building, then your spray foam contractor is correct. This type of insulation job creates an unvented roof assembly. You certainly don't want any air leaks at the ridge.
