Spray foam insulation with exterior foam board insulation
![](https://secure.gravatar.com/avatar/18b033897874d202224d1391c7aa5624?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
We’ve recently remodeled a 2 story farm house in central illinois, we had 2 inch closed cell sprayed in the exterior walls and 20 inches of cellulose blown in the attic. My question is can I put 1 inch foam board on the exterior of my home? We will be re-siding within a next year or two. The winds in the wide open country are brutal in the winter time, will the sandwiching the 3/4 tongue and groove between 2 inch closed cell and 1 inch foam board cause issues. If so what else can I do to provide more thermal break and better air sealing from the exterior.
