Something wrong with article
![](https://www.greenbuildingadvisor.com/app/uploads/assets/avatars/19611-avatar-1593614988-100x100.png)
https://www.greenbuildingadvisor.com/green-basics/crawl-spaces
this article seems to trail off at the end with three … and not finish it’s thought.
was enjoying the read..
“ Still, sometimes a crawlspace makes sense. Crawlspace walls should be insulated with rigid foam, and sealed rather than vented. Crawlspaces should be treated as if they were …”
Ryan,
You're right -- something is wrong. I would finish the sentence "...short basements."
For a look at the article on the Wayback Machine, here's an earlier version:
Earlier version of crawl space article
