Some questions on real fuel usage calculations
![](https://secure.gravatar.com/avatar/3351af7969f697043d1fd36af65b760f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fi.png&r=g)
I have some questions on the Dana Dorsett article using real fuel consumption to measure heat load.
https://www.greenbuildingadvisor.com/article/replacing-a-furnace-or-boiler
I have two factors running the calculation. The first is that my boiler is an oil burner retrofitted to burn gas. The original boiler seems to have been a 151,000 input and 131,000 out (funnily enough it looks like the same Weil-McClean in the article). When I looked at the guide on the replacement burner they seem to have tuned it to the same 151,000 BTU input as the original.
Am I able to just use the numbers on the boiler to calculate efficiency? Or do I need to do some additional measurements?
My other issue sounds crazy. I keep the thermostat at 68 most of the time, but the house has wildly varying temperatures. Upstairs bedrooms can be 10 degree hotter and the kitchen 6-8 degrees colder (I’ve got some airsealing to do.)
Can I just use the 68 degree temperature when the real temp is that all over the place?
thanks!
I'm going to bump this backup hoping someone can suggest an answer. The efficiency part is especially vexing.
The efficiency part is easy - a non-condensing gas boiler maxes out at about 80% efficiency. So no more than that, probably lower in practice.
Awesome, thank you.
This thing is oversized by what looks like at least 2x.... yikes.
