Smoke odor
![](https://secure.gravatar.com/avatar/51ff86eb2e0f6845387d2baaea1a5efc?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hi, We are restoring a severely fire damaged home and while many components have been simply removed (down to the studs), the framing needs to be treated to eliminate the smoke odor. Our research has pointed us toward alcohol based shellacs. Some say first use an oil based primer and then the shellac. Can you advise?
Thanks, jk
Joseph,
This is the type of work where it's wise to hire an expert. Many restoration contractors specialize in smoke-damaged properties -- and hiring such a contractor is usually worth every penny. I don't advise a DIY approach.
http://m.homedepot.com/p/OdoBan-5-oz-One-Shot-Fire-Odor-Bomb-Fogger-9705A62-5A/202560684
This fogger is used in fire restoration and works well in the rental industry at removing unwanted smells. Spray painting the studs will help, but even the best Fire damage restoration by the so called professionals are questionable at best. Good luck. Been through a house fire and It's not easy.
Martin, Thanks for your take on it. Unfortunately, we are obstinate and believe we can do most anything as well as an expert. Most of them seem to be oriented towards an aggressive sales pitch and look to work directly with the insurance company. In this case, that ship has sailed (this fire occurred a year ago). We (a design/build firm with 35 years experience), are performing the entire restoration with significant architectural alterations, so there won't be that much scarred lumber left. The companies that specialize in fire restoration/odor removal are not very interested in that small a job. We'll be spraying an alcohol base shellac / primer and following up with a Lysol based mold treatment in areas. I'll let you know how it goes. Thanks,
