Smart baffles in cathedral ceiling
![](https://secure.gravatar.com/avatar/e95a3296399133b1f9eebafa96ae3e06?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
Hello everyone,
I am building a home that has cathedral ceilings and had a few questions. My rafters are 2x12s and I am going to be installing smart baffles since I will be insulating with open cell spray foam. I live in Carlsbad,NM we don’t get a lot of rain and is pretty dry most of the year since we live in a desert. Anyways when I had the insulation guy come look at the house he said that I wouldn’t need baffles and not to install them. My only concern is that where I live the day temps can change drastically from the night temps which can be more than a 30 degree change and I fear than condensation could make my roof decking and rafters mold. Any information on this would be great.
Eric,
Installers are spray foaming roof cavities with open cell foam in pretty much every climate zone. Sometimes they work, sometimes they don't.
https://www.greenbuildingadvisor.com/article/open-cell-spray-foam-and-damp-roof-sheathing
I'm curious to know as well. I'm finishing out a cathedral ceiling space above my garage in SoCal. I was told I didn't need baffles, only insulation. I left a gap between drywall ceiling and fiberglass, and I need to install a trim board at the peak, but there is condensation up there. Last night was 48˚ and low 70's today when I noticed heavy condensation. I can't install baffles now, and I don't think it would help anyhow. But the temperature fluctuation is definitely at play. Looking at a more robust ridge vent like the Cobra Ridge Vent or similar.
I'm going to seal the ridge cap in drywall and mud/caulk seams before I attach the faux ride beam facing. This will cover those exposed surfaces. Since me eaves are not vented/open, the air is coming from inside the room, not the rafter space. Sounds like your eaves might be vented?
K_weston,
You can use permeable insulation (batts, cellulose) in climate zones 1, 2 and 3 without baffles or ventilation, but you need a vapor-diffusion port at the ridge - and a good interior air-barrier.
https://www.greenbuildingadvisor.com/article/vapor-diffusion-ports
Why not us a nailbase for a thermal bridge (ACFoam® Nail Base) then have him spray some closed cell first then open?
This way the "first condensing surface" will never reach the dew point & thus no vapor to liquid ...
That's what I did on my cathedral ceilings in NH
~ former spray foam contractor
