Small vertical heat pump?
ScaleBack | Posted in General Questions on
Have a small upstairs gas furnace, fits in a narrow, purpose-built closet. Ducted for 2nd floor.  Are there heat pumps on the market that would fit a small space like that?  Current gas unit is 46″ tall before fitted into ducts, 22″ wide.  Have not found anything compact enough so far.  Access to outside not a problem.
  1. canada_deck | | #1
    As a starting point, you've got to give the three dimensions... Width, height, length.
    1. ScaleBack | | #2
      Hi, Sorry for the delayed reply. In addition to the current gas unit being 46″ high before fitted into the ducts and 22″ wide - it is 29" in length. The closet itself is: 79" high, 24" wide and 41" in length. There is also 14" below the bottom of the furnace floor for the intake vent. If I can get a small heat pump in that closet space, this is doable and I would convert.
  2. ScaleBack | | #4
    Yes! Thank you.
  3. walta100 | | #5
    Does the current system have central air with a coil on top of the furnace?
    Do you have a floor drain by the furnace as the new heat pump needs to drain condensate.
