Insulating a Slab on Grade and Moisture Control
I recently purchased an older home (1977) slab on grade with no insulation or vapor barrier under the slab, in fact it was poured on loose shell rock. I found all the tack strips on the outside walls have been wet and are almost rotted and I can smell mildew on the carpet edges when I pulled it up to paint. I’ve done lots of reading and can’t find a solid answer so: how do I stop the moisture from coming in and insulate the floor under the carpet and the bottom around the outside?
It might be from condensation and not moisture intrusion. The carpet acts as a slight insulation layer keeping the slab cool enough to condense the humidity in the room.
Do a search on here for insulating basement floors for ideas on how to stop this.
There are a number of details here that you might want to consider for your situation: Building Plans for Energy Efficient Basement Remodeling.
