Slab insulation
![](https://secure.gravatar.com/avatar/92bad00094f7c52c5abb23d47f59ce3c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hi,
Is there a specific spray foam that should be used to fill in gap mostly around pipes and conduit when installing insulation below the slab prior to pouring?
The EPS foam I am using is rate for 16 PSI so I am not sure if the spray foam must also be rated for something similar. I was thinking of simply using something like the GREAT STUFF Gaps & Cracks.
Thank you,
Arnold
You don't need anything fancy here. You're just filling gaps to keep the concrete out. Any canned foam will work.
Thanks for confirming Peter.
