Plywood and Foam Assembly for Finished Basement Floor
![](https://secure.gravatar.com/avatar/bd616552da52e136d933aa3ff68d83eb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
We are finishing a basement and trying to end up with a floor that is carpeted. I’m considering foam board + plywood/osb subfloor approach in Martin’s article: https://www.greenbuildingadvisor.com/article/installing-rigid-foam-concrete-slab
How flat does the floor need to be for the foam + plywood/osb approach if the goal for the finished surface is just carpet? Can 1″ thick of XPS tolerate hills of 3/8″ and perhaps some shallow valleys? It seems pretty stiff, but I’m not sure if it conforms to the floor a bit over time.
I’ve read several articles about the foam + plywood approach but I’ve not seen the flatness requirements of the floor dealt with in any of them.
