Skylight vs. Window in Bathroom- Which is the Lesser of Two Evils.
![](https://secure.gravatar.com/avatar/f312305bae30c075a81a7a256fe84dc1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
We are converting a narrow, long closet into a bathroom that will have a shower at the end which is an exterior wall (north exposure). As this will be the main bathroom for all the upstairs bedrooms, there is a high desire to have natural light. Our options are to either put a window in the shower or a skylight over it.
The window presents the problem of both sides needing to be water resistant. So I wonder, are both interior an exterior sills sloped along with the underlying pans and not sealed? Is there a back-dam dead center or none? For the interior, will the exterior tapes or fluid applied solutions be compatible with the shower systems (Schluter)?
As for the skylight, well it’s a big hole in the roof and any penetration there makes me nervous, especially a retrofit one. Should there be special conditions to ensure the best waterproofing if we go this route instead. I feel confident in water proofing windows (at least on the exterior), but I’m not as familiar with the best practices on skylights.
Putting aside the waterproofing durability concerns, I would imagine that the skylight is a less favorable option from an energy perspective as well.
So which route would you choose and what would you do to ensure the best durability and energy efficiency?
I'd say the window is the lesser of two evils.
I have been pleased with the suntunnel in my guest bathrooms shower.
I've had bathrooms with windows in the shower for many decades. They've not been a problem, even though there's condensation on the windows. They do require infrequent maintenance, which we do, and ventilation is important. A suntunnel (per Walta) with bathroom fan would seem a very good solution. If you don't do maintenance then I'd avoid the window option.
Also agree that a solar tube (sun tunnel) might be your best option.
There are youtube videos about waterproofing a window in a shower. It's not difficult to do. Just take your time and don't take any shortcuts during installation. Use a well insulated window with zero wood as part of it's construction.
Sun tunnels work great. But a window can certainly be made to work as well. Here's a link to a Fine Homebuilding article if you decide to go the window route. I would opt for a stone or acrylic (Corian) single piece sill as well.
https://www.finehomebuilding.com/project-guides/tiling/waterproofing-a-window-in-a-tiled-shower
