SIP cold roof
di57 | Posted in GBA Pro Help on
I am a SIP homeowner, with too many problems to describe here!  But, in the midst of a major roof remodel (installing a vented or “cold” roof on top of 2007 sip panels) we cannot find a vented drip edge that has a extended drop profile (3”) into the gutters.  We are using 2x4s, and 1/2” plywood for our materials.  Can anyone advise?
  1. Zdesign | | #1
    Chances are you will have to have one made on a metal brake which should be fairly easy for any exterior trim guy. I know ABC sheet metal can make any profile you give them a sketch of if you are planning on doing the install yourself.
    1. di57 | | #2
      Thanks for your reply! I appreciate hearing from you. We’ll investigate.
      1. Bryce_V | | #3
        di57,
        Do you have an update on your cold roof project and finding trim to work? We're building a SIP house right now and starting with a cold roof.
        Thanks,
        Bryce
