Sill seal on a 4in slab on grade
![](https://secure.gravatar.com/avatar/df70371997542d35e031530b34d375cf?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I have a 20×24 detached garage being built, sheathing is on, how should I properly flash the base? My plan is to use a butyl rubber tape at the bottom and accoustic sealant on the inside at plate to slab. Since siding will be too low to the ground I plan on using 6″pvc board as a starter strip before I begin the vinyl siding, how and where should I use flashing or drip edge, should it below the pvc or above pvc and below 1st run of siding or both? I will be using tyvek vapor barrier.
