Siding over T1-11
J6204 | Posted in General Questions on
I have a house with T1-11 as it’s siding/ sheathing. It has a flat roof and no overhang. I want to put horizontal and vertical siding over the T1-11 with some  WRB and coraplast strips behind it. The facia has vents drilled in it currently. In this case would you recommend eliminating the vents. ( the roof has virtually no pitch ). Would you create an air gap at the top of the siding or not?
    Dana Dorsett | | #1
    I need a picture to visualize more clearly what's going on here.
    MALCOLM TAYLOR | | #2
    Jim,
    Rain-screen cavities perform better when vented top and bottom - but they perform just fine when vented at the bottom only.
    I'm sorry, I don't have enough experience retrofitting flat roofs to comment on the fascia-vents.
  3. GBA Editor
    Martin Holladay | | #3
    Jim,
    It sounds like you are asking two questions -- one about the usefulness of a rainscreen gap behind your siding, and one about the best way to vent a low-slope (flat) roof.
    For more information on rainscreen gaps, see this article: "All About Rainscreens."
    For more information on venting a low-slope (flat) roof, see "Insulating Low-Slope Residential Roofs."
  4. J6204 | | #4
    This is what it looks like
  5. user-1072251 | | #5
    Building Science has a graph (which I cannot find right now) showing the depth of overhang compared to damage from water running off the roof to siding - turns out that the larger the overhang, the better the siding holds up. Before you add new siding, increase your overhangs.
