Shower wall assembly
![](https://secure.gravatar.com/avatar/f42e9e06515581c5fc743ace69362edb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
In climate zone 5b. I’m remodeling a shower that is against an exterior wall. I’m wondering what type of insulation is best for this assembly. I haven’t yet taken the old out so I’m not sure of exterior material. I’m gonna assume at this point it is house wrap over OSB, with metal siding that looks a lot like the cheap vinyl siding. Also, not yet sure on materials for the shower itself so if I could get some info on whether I do fiberglass surround walls or if I go with cement board with tile finish it would be much appreciated.
If you do a tile finish go with a full waterproof system instead of cement board such as Laticrete HydroBan or Schluter Ditra. They both make panels that are a substitute for cement board. Also consider urethane grout like from Bostik TruColor for a sealer-less finish.
